2003 Honda Accord V6 Please Reply !!!!
2003 HONDA ACCORD
DESERTROSE
  • 12 POSTS
Hi-
I have Accord v6 sedan.My question is that when my car is not start or warm its colant level in bottle indicates below low but when i drove by for 30 mins level rise up in middle of Low and High.
Should i add more colant into radiater bottle ?
Thanks
May 10, 2007 at 1:41 AM
SERVICE WRITER
  • 9,123 POSTS
I like to adjust the coolant leve when the engine is cold, putting the level up to the "cold" marker if it has it. As long as it is in the range required and your not losing coolant or have any high teperature troubles, i wouldn't worry about it.
May 10, 2007 at 1:49 AM
DESERTROSE
  • 12 POSTS
I just had High and Low Levels and its not leeking any colant. So you said that i should up fill the level to High.
Secondly should i add colant alone or should i add water with that?
Thanks fo Replying.
May 10, 2007 at 2:00 AM
SERVICE WRITER
  • 9,123 POSTS
Add a 50% coolant and 50% water mix to te reservior. Take it to the "high" if you want, but anywhere in between is acceptable.
....and yo welcome
May 10, 2007 at 8:19 AM
