2003 Honda Accord upper door sash reinstallation
MIKE232232
Noises problem
2003 Honda Accord 6 cyl Two Wheel Drive Automatic
I had door visors installed on my car, however the tape stpopped working and the driving over bumbs became rattled and noisy. I removed the defective visors but I see that the upper door sash of the door is devastated by the glue adhearing to it. The black overcoad is peeled off and the only way to fix the problem is to replace the door sash on each side of the car. The sash itself only costs 20 dollars hovever replacedment they quoted me 150 per door so I decided to give it a go myself. I noticed on this site detailed instructions with pictures for removal of the back door in 4 door honda model. I was wondering if it was possible to get detailed instractions as to how to remove upper door sash on 2 door model of my 2003 Accord, thanks in advance
Sep 15, 2009 at 5:05 PM
KHLOW2008
  • 41,812 POSTS
Hi mike232232, Here are the procedures with diagrams. DOOR SASH TRIM REPLACEMENT 2 - DOOR NOTE: Take care not to scratch the door. 1 . Lower the glass fully. 2 . Remove the mirror. 3 . Slide the door glass outer weatherstrip (A) forward to release the hook (B) on bottom of the door sash trim (C) from under the rear end of the weatherstrip.
https://images.2carpros.com/forum/automotive_pictures/192750_DoorSash02AccordFig47_1.jpg
4 . Pull back the door weatherstrip (A) at the rear upper corner, and pull the glass run channel (B) away as needed, then remove the screws.
https://images.2carpros.com/forum/automotive_pictures/192750_DoorSash02AccordFig48_1.jpg
5 . Pull up the door sash trim (A) to release the hooks (B) from the holes in the sash, then remove the trim.
https://images.2carpros.com/forum/automotive_pictures/192750_DoorSash02AccordFig49_1.jpg
6 . Install the trim in the reverse order of removal.
Sep 18, 2009 at 4:59 AM
MIKE232232
these instructions are for lower door sash trim, I needed to replace the upper door sash, the spot where door visor would be installed You gave instruction for lower door sash (3,4 in the picture) I needed instructions for door sash (5,6 in the picture) thanks
https://images.2carpros.com/forum/automotive_pictures/409887_door_panel_picture_1.jpg
Sep 18, 2009 at 7:06 AM
KHLOW2008
  • 41,812 POSTS
Thise are known as outer mouldings. FRONT DOOR OUTER MOLDING REPLACEMENT Special Tools Required KTC trim tool set SOJATP2014 NOTE: "¢ If you remove the door outer molding, replace it with a new one because it will bend during removal. "¢ Put on gloves to protect your hands. "¢ Take care not to scratch the door. "¢ Use the appropriate tool from the KTC trim tool set to avoid damage when prying components. 1 . Remove these items: "¢ Mirror "¢ Door sash trim, 2 -door "¢ 2 . Remove the door outer molding (A). -While removing the upper edge of the door outer molding from the edge of the sash, cut the double- sided adhesive tapes (B) with a utility knife, then remove the molding.
https://images.2carpros.com/forum/automotive_pictures/192750_DoorMoulding03AccordFig54_1.jpg
3 . Scrape off the remaining double- sided adhesive tape from the sash, then clean the sash surface with a sponge dampened in alcohol. 4 . Install new door outer molding in the reverse order of removal, and note these items: "¢ Push the clip and the adhesive portions into place securely. "¢ Make sure the upper and lower sides of the molding are catching the edges of the sash properly.
Sep 18, 2009 at 7:23 AM
