Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Accord
Engine
Starter
2003 Honda Accord Starting
2003 HONDA ACCORD
107,000 MILES • 4 CYL • FWD • AUTOMATIC
GODZSON
MEMBER
1 POST
Engine drags at the start. Battery, Alternater, and Starter checks out fine.
Apr 14, 2009 at 9:45 AM
KHLOW2008
Experienced Mechanic
Hi Godzson,
You mean the engine is not cranking up to speed?
Did you check the starter solenoid wire connectors? A loose connector would cause such a problem.
Check the ground cable from battery to trans, look out for frayed wires.
Apr 20, 2009 at 9:58 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
