2003 Honda Accord Starting
107,000 MILES • 4 CYL • FWD • AUTOMATIC
GODZSON
Engine drags at the start. Battery, Alternater, and Starter checks out fine.
Apr 14, 2009 at 9:45 AM
KHLOW2008
  • 41,812 POSTS
Hi Godzson,
You mean the engine is not cranking up to speed?
Did you check the starter solenoid wire connectors? A loose connector would cause such a problem.
Check the ground cable from battery to trans, look out for frayed wires.
Apr 20, 2009 at 9:58 AM
