2003 Honda Accord smoking
BOOGIESMAMA
2003 Honda Accord 4 cyl Front Wheel Drive Automatic
occasionally my engine will smoke but i dont see anything dripping. someone told me it may be my valve cover gasket. how can i tell??
Feb 8, 2010 at 5:42 AM
ERNEST CLARK
  • 1,730 POSTS
Whenever your engine starts to smoke, pop the hood and take a look.
It's usually oil dripping onto the exhaust manifold. It could be coming from a valve cover or intake manifold.
Look for an oily build up against the mating surfaces at the top of your motor.
If it's a valve cover gasket, write back and I'll walk you through the fix. If it's an intake manifold, I can walk you through that also, but I don't recommend you tackle that yourself if you aren't already familiar with that procedure.
Feb 8, 2010 at 1:03 PM
