2003 Honda Accord replace catalystic converter
83,000 MILES • 6 CYL • FWD • AUTOMATIC
BUSY284
i replaced my catalystic converter because the check engine light was on and my mechanic said it was the catalystic converter after two weeks it came on again the code said its the cat again. Do i have to replace it again or could it be o2 sensor. replaced it with a eastern converter. trhe rear cat was replace.
Apr 2, 2010 at 2:32 PM
HONDA TECH 1818
  • 536 POSTS
There is 3 catalytic converter in your V6 Accord, one is in the front of the engine and the other one is in the rear of the engine. The DTC P0420 is for the rear catalytic converter and P0430 is for the front catalytic converter. The catalytic converter at under the car will not set a DTC. What DTC did you get? And which cat did your mechanic replaced?
Apr 2, 2010 at 4:35 PM
