2003 Honda Accord RE:NEW BRAKES AND STIIL ACT UP
76,000 MILES • 4 CYL • FWD • AUTOMATIC
DANTHETECH
WE HAVE A 2003 HONDA ACCORD AND IT HAS 76000 MILES AND WE HAD 3 SETS OF BRAKE PADS ADN 2 SETS OF ROTORS AND THEY JUST PUT NEW WHEEL BEARINGS AND WHEN WE TOOK IT HOME IT SQEALED FROM THE TIME WE LEFT THE SHOP TO MY HOME THE MECHANIC SAYS THERE IS HIVES AND DIRT BUT I BLEW ALL THAT OUT AND IT STILL DOES IT BUT IT ALSO DOES IT WHEN YOU HIT SPEED BUMPS AND TURNING RIGHT WHAT CAN THIS BE THANKS
Jun 19, 2008 at 2:39 PM
KHLOW2008
  • 41,812 POSTS
Hi DANTHETECH,
Check and see if the backing plates are brushing against the rotors.
When the plates are too near, any turning ot the steering will cause the plates to scrape against the rotor.
It coulds also be the CV joint dust seals running dry causing the noise.
Check for any other rubber parts brushing against the driveshafts.
Jun 20, 2008 at 1:33 AM
