2003 Honda Accord 4 cyl Front Wheel Drive Automatic
had my air condioning work on and my radio stop work and it has a popping noises and the radio come on ever night then
Tuesday, July 20th, 2010 AT 9:56 AM
KHLOW2008
MECHANIC
Hi money64,
Your questions seems incomplete.
Can you rephrase the question and provide more details?
SPONSORED LINKS
Tuesday, July 20th, 2010 AT 12:41 PM
MONEY64
MEMBER
My air condition got worked on and I am sure that they took the radio loose. The radio pop on and off. I was inform that a wire might be loose that has some thing to do with the radio
Tuesday, July 20th, 2010 AT 12:48 PM
KHLOW2008
MECHANIC
It is possible that a ground circuit is not securely installed after the A/C work. Only a physical inspection and testing would be able to get to the bottom of the problem.
