Took fuse out to check and then replace it and radio has the word code on it. Also the light on the radio does not work. What can I do?
Sep 21, 2009 at 4:02 AM
KHLOW2008
✓Experienced Mechanic
Hi Kesse678,
There is a security code for the radio and if power is disconnected, you would have to key in the code again. This code should be found on a card in the owner's manual. If it is lost, you would have to call the dealer to get the code.
To input the code, use the preset buttons. If you had tried pushing the buton a few times, yu need to remove the fuse again to reset before you can enter the code.
