2003 Honda Accord p0970
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOONSTAR
I got check engine light, the code is p0970 which related to pressure control solenoid C. Will this symptom fixed if I replace this solenoid? What else can cause this problem?
Thanks,
Moonstar
Aug 27, 2010 at 8:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely the A/T clutch pressure control solenoid valve C does need replaced but first check the wiring to this solenoid.
Aug 27, 2010 at 12:41 PM
