OVERHEATING
LOANIO
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 86,000 MILES
It starts too overheat in stop and go traffic but when I get on the freeway and floor it the temperature goes back too normal can u help me with this do u know what the problem is?
Wednesday, July 28th, 2010 AT 4:36 PM
KHLOW2008
  • 41,814 POSTS
Hi LOANIO,
Check the coolant level in the radiator, if it is low, it would result in overheating when vehicle is moving slowly or stopped.
This gudie whoudsl help
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Check if the cooling fans are turning on. If they don't, the radiator is not being cooled when vehicle is stationary or moving slowly.
Saturday, July 31st, 2010 AT 2:38 PM
ZANYJB
I had to get a new cooling fan to fix my prlb, em cost me $78.00 to fix it
Wednesday, December 4th, 2019 AT 2:18 PM
LEROY7
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 93,000 MILES
When I stop and let my car idle on hot days with the A/C on the RPM's will jump up to 1600 and the car will start to overheat. I tried to tap the throttle to get the RPM's down but it had the opposite effect, the RPM's went up over 2400. Of course with the RPM's that high I am not able to shift the car into drive and have to shut the vehicle down to cool off. The time that I didn't tap the throttle I was able to shift the vehicle into drive and the vehicle cooled off going down the highway. The antifreeze level is fine and there are no problems during any other operation.
Wednesday, December 4th, 2019 AT 2:19 PM (Merged)
F4I_GUY
  • 3,302 POSTS
Is the cooling fan coming on when you are over-heating?
Also, the high idle is most likely caused by a dirty or faulty IACV (idle air control valve) You can try servicing it (cleaning it) first before replacing it.
YUNES
  • 2003 HONDA ACCORD
Engine Cooling problem
2003 Honda Accord 4 cyl Front Wheel Drive Automatic
What can be causing my car to overheat, both fans are working, there is plenty of coolant in the reservoir. Thanks for your help.
Yunes
  • 31,937 POSTS
Hi there,
check that the thermostat is working, the pressure cap is holding correct pressure, there are no external coolant leaks and the radiator is not part blocked.
Mark (mhpautos)
