2003 Honda Accord Lighting
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIM CALCATERRA
The lights for the radio as well as the radio controls and the heat/AC controlsl will not light up. I checked fuses and all are ok any idea what to check?
Jul 29, 2010 at 9:40 AM
KHLOW2008
  • 41,812 POSTS
Hi Jim,
Are the dash backlights and taillights working?
Jul 31, 2010 at 9:10 PM
JIM CALCATERRA
All other light work. I have check all fuse and found no problem.
Aug 1, 2010 at 12:56 AM
KHLOW2008
  • 41,812 POSTS
Was anything done prior to this occurring?
Aug 1, 2010 at 1:39 AM
SHOTGUN682
[quote:8c59a6f67f="KHLow2008"]Was anything done prior to this occurring?[/quote:8c59a6f67f]
This is a common problem for the Accord
Honda extended the warranty for this problem to 7 years 100,000 miles
You will need a new display head it cannot be repaired and there is no fuse for it
Aug 3, 2010 at 2:59 AM
KHLOW2008
  • 41,812 POSTS
Hi Shotgun682,
Thank you for the input.
Yes, there is a warranty extension for the radio with dim or dark display.
The warranty mileage has expired for Jim's vehicle as it has reached 115k miles. Maybe you can try your Honda dealer to see if they can give you a goodwill warranty on it.
Here are some details of the TSB.
WARRANTY EXTENSION: AUDIO-HVAC DISPLAY IS DIM OR DARK
TECHNICAL SERVICE BULLETIN
Reference Number(s): 04-027, Date of Issue:  July 07, 2009
HONDA:2003-04 Accord
CATEGORY:Electrical
Superceded Bulletin(s): 04-027, Date of Issue:  February 05, 2008
Related Ref Number(s): 04-027
ARTICLE BEGINNING
REVISION SUMMARY
In some audio units, a component failure on the PCB (printed circuit board) could cause the audio display to become dark or dim, and prevent the audio/HVAC panel buttons from illuminating.
To ensure that customers have adequate warranty coverage for this potential problem, American Honda is increasing the warranty on the audio unit display to 7 years or 100,000 miles, whichever occurs first. For other defects, the standard 3 years or 36,000 miles warranty applies, whichever occurs first.
VEHICLES AFFECTED
NOTE:
Affected vehicles do not have the navigation system.
NOTE:
Because of a class action settlement, the warranty extension coverage for the audio unit display on affected vehicles purchased or leased between April 13, 2002, and November 7, 2006, is now 7 years or 105,000 miles , whichever occurs first.
The mileage is 105,000 miles because there is a 5 percent allowance.
Aug 3, 2010 at 3:48 AM
