2003 Honda Accord idle
21,000 MILES • 6 CYL • FWD • AUTOMATIC
DBK
Engine sputters and idles rough when in gear at a complete stop; after shifting to park the rough idle continues and the engine will stall altogether;the car is now difficult to start but when I am able to get the car in gear I am able to proceed. This problem is of two days duration beginning after a short (40 mile) drive up an easy grade mountain road. Any help will be greatly appreciated. Thanks.
Jun 18, 2008 at 12:06 PM
LEGITIMATE007
  • 5,121 POSTS
I would check the idle air control valve, and check mass airflow sensor/with airfilter and breather.
Jun 18, 2008 at 12:38 PM
LEGITIMATE007
  • 5,121 POSTS
may want to check fuel pressure just to rule that out all together, but this and the other couple of things ive mentioned should clear your symptoms right up
Jun 18, 2008 at 12:39 PM
ITSALLGOOD
  • 37 POSTS
Sounds like Mass Air Flow sensor to me.
That would be the first thing I would check.
Jun 19, 2008 at 3:43 PM
LEGITIMATE007
  • 5,121 POSTS
thanx for the input
Jun 19, 2008 at 3:49 PM
