2003 Honda Accord Grinding Noise
120,000 MILES • 4 CYL • FWD • AUTOMATIC
LAYTOSHA
My car makes a grinding noise while in motion and when you step on the gas. sometimes it also has an egg smell
Aug 6, 2009 at 6:53 AM
F4I_GUY
  • 3,302 POSTS
The egg smell is most likely due to over-fueling. You are smelling sulphur from your hot catalytic convertor. It can also mean that your convertor has failed as well.
The grinding noise could be a wheel bearing, low brake lining or a rubbing backing plate.
Aug 6, 2009 at 9:58 AM
