2003 Honda Accord Door locks
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
HONEYBUNNY4989
I am unable to lock all four doors either by the button on the door nor by my auto key lock device. I have to manually push down the door locks. Also I need to manually use my key to open the truck.
How expensive might this possible be? If I let this go will eventually my electric windows quit working or are they on a different device?
Thanks Diane
Aug 27, 2009 at 12:14 PM
KHLOW2008
  • 41,812 POSTS
Hi Dianne,
Central locking and power windows are on separate ciurcuits so should not afffect each other.
The most likely cause of your problem would be a bad door lock control unit or its wiring. Check for blown fuses in underhood fuse box.
Aug 30, 2009 at 9:20 PM
