2003 Honda Accord Check Engine LigtOn
MRJAY8888
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 52,000 MILES
Check Engine Light On. Where do submit the donation to
Sunday, January 6th, 2008 AT 1:24 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
The Engine check light is a visual indication that the ECU has logged a fault code. This will normally be an engine management problem that it has detected. The code is held in the memory untill it is retrieved. Get you mechanic to retrieve the code and it will be the starting point to detect the problem area.
Mark (mhpautos)
Monday, January 7th, 2008 AT 2:59 AM
