2003 Honda Accord catalyc converter going out
237,000 MILES • 4 CYL • 2WD • AUTOMATIC
TAMMYLAURAN
sorry don't know how to spell it. I had it diagnosed and they said the catalyc converter was going out. The car hesitates at certain speed just a bit but it still runs fine. how much should i expect to get this fixed?
Jul 8, 2010 at 1:54 PM
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_c_6.jpg
Note:Part and labor varies within location. Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below: Possibilities: Inspect and test all the following listed below: Oxygen sensor. Catalytic converter. Fuel injectors dirty/sticking. Mass airflow sensor/Airflow meter. Throttle position sensor. Crankshaft position sensor Manifold absolute pressure sensor. EGR Valve Fuel pressure regulator leaking or defective fuel pump. False air leakage. Fuel contamination. Foul/defective spark plugs. Open spark plug wires. Ignition coil/Coil packs defective. Incorrect ignition timing. Cap and rotor. Note:If it doesn't apply disregard
Jul 8, 2010 at 3:42 PM
