2003 Honda Accord Car shaking
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
BTERACE2
Car violently shakes at and around 60 mph when applying gas. Will stop as soon gas is let off; will not shake if coasting or decelerating at this speed. Car has not been in an accident. Have had 3 mechanics look at it and verify shake but not able to determine the problem. Work done to try to remedy problem: balanced tires, replaced all tires, replaced passenger side axle, new rotors and brakes, rims not bent, motor mount is good, shocks are good. Problem has been occurring for over a year with no other entailing problems. Please advise.
Jun 28, 2008 at 9:13 AM
KHLOW2008
  • 41,812 POSTS
Hi bterace2,
The symptom described is relevant to the driveshaft inboard joints and trans differential.
Check inboard joints for lubrication and excessive side clearance due to wear.
Jun 28, 2008 at 2:40 PM
