2003 Honda Accord broken front wheel stud
113,574 MILES • 6 CYL • FWD • AUTOMATIC
KJPARKHURST
can i repair at home myself? passenger front wheel stud. while removing 4/5 lugs nuts. one sheared off. how hard to repair it!!! thanks for your time. kevin in northern ca
Apr 10, 2009 at 8:26 AM
KHLOW2008
  • 41,812 POSTS
Hi kjparkhurst,
Not too easy.
You need to remove spindle nut, pull hub slightly out for the new stud to go in. Remove/loosen old stud before loosening spindle nut.
After installation, tighten and loosen spindle nut a few times to get the hub seated fully. Improper installation would cause the bearing to go bad.
Apr 15, 2009 at 5:56 AM
