2003 Honda Accord Brake or transmission?
85,000 MILES • 4 CYL • FWD • AUTOMATIC
FFFIDEL
why does the shifting lever gets stuck or Lock?
when i turn the car on I can't change the gear to operate the car, it won't change to any other gear and just stays on park. I noticed that when I press down the brake and it makes a click then it changes but now it wont do it and in consecuense I cannot change gears. Please advice!!!
Thanks
Nov 10, 2008 at 3:25 PM
  • 31,937 POSTS
Hi there,
You will need the safety lockout solinoid and switch inspected, on some models there is an override, a small hole near the gear lever that if you push a small probe into it it will release, check this out.
Mark (mhpautos)
Nov 10, 2008 at 3:35 PM
