2003 Honda Accord ac not comming on
2003 HONDA ACCORD
152,000 MILES • 6 CYL • 2WD • AUTOMATIC
J GATES
My question is this. My auto mode will light up but the clutch will not kick in on the compresor. When I push the up button on the fan switch the light goes out. I am trying to find out if its a temp issure or is the compresor bad. I check all fueses and they are ok. Don't know if there is one by the compresor. Also the other lights as well as the ac light will go out when I push the up button on the fan switch.
Aug 29, 2008 at 8:28 AM
KHLOW2008
  • 41,814 POSTS
Hi J GATES,
You need to check if there is enough freon in the system.
Is power getting to the compressor clutch coil?
Did you check/test the compressor relay?
Aug 30, 2008 at 6:04 AM
