2003 Honda Accord A/C
YARAMSD
Air Conditioning problem
2003 Honda Accord 4 cyl Four Wheel Drive Automatic 67000. miles
My a/c is blowing hot air, I'm not sure if the compressor is turning on or not. I turn the temp. all the way down to check and see if it it cooling and have no results, what can it be?
Jan 26, 2009 at 5:00 AM
KHLOW2008
  • 41,812 POSTS
Hi yaramsd,
You should check if the compressor is engaging.
Does the fans work when A/C is turned on?
Feb 1, 2009 at 5:12 AM
RRSHATTA
  • 7 POSTS
try re-gasing you A/C. the gases are sold at walmart. its simple
Feb 20, 2009 at 11:25 PM
KHINDI
[quote:3e7beff8fa="yaramsd"]Air Conditioning problem
My a/c is blowing hot air, I'm not sure if the compressor is turning on or not. I turn the temp. all the way down to check and see if it it cooling and have no results, what can it be?[/quote:3e7beff8fa]
Mar 2, 2009 at 10:42 PM
