2003 Chevy Blazer Chirping Noise
HEATHERFRASERD
I am at the end of my rope.
Aug 06 - replaced serpentine belt
Jan 07 - tune up, change fuel filter, put in spark plugs [twice - they put in the wrong ones to start!], replace fuel injectors, replace fuel pressure regulator.
This fixed the check engine light that had been on since I bought it in August!
After all that it ran GREAT. For 3 weeks.
Now:
1 - chirping sound a few times a minute - reminds me of mice
2 - sounds like a jet engine off and on
3 - slight hesitation when speeding up/slowing down
4 - a bit of a rougher ride [the tire pressure is good according to the scale for cold tires]
The noise isn't enough to hear when the heater is on. The weather did drop to -38C [-50C with a windchill] - the only thing I did different was put in a bottle of gasline antifreeze when I filled it up. Its starting fine, no codes/check engine light [so no misfires right?]
I have tried it without the heater on [possibly ac someone told me] & the noise/problems are still there. I've also tried it in 4 wheel drive vs 2 wheel drive - exactly the same.
Is this due to the cold weather, a misaligned belt [the chirping?] ... or something drastic?? Thanks for the help
Feb 6, 2007 at 7:29 AM
SERVICE WRITER
  • 9,123 POSTS
Hi Heather,
Doesn't sound like anything to pull your hair out over just yet.
The cold is problaby having an effect on the belt. The tensioner may be on the weak side as well. You can spray some belt dressing on the belt to see if it stops the noise, if not there may be a pulley bearing going bad.
Keep an eye on the temperature gauge and watch to see if the jet engine noise happens when it is about the same temp when it starts to happen.
Not sure on the hesitation, there may be codes stored that didn't set the CEL. Check your transmission fluid level.
The rough ride is probably cold related. When the truck sets the tires get a flat spot that freezes that way until the tires get warmed up and back to shape.
The ride is different when it is this bitter out.
Feb 6, 2007 at 11:21 AM
Suggested Repair
Treat the chirp as a cold-related belt issue: spray belt dressing and, if the noise remains, inspect the tensioner and pulley bearings. Note whether the jet-like noise starts at a consistent temperature. For the hesitation, scan for stored codes that did not turn on the check engine light and check the transmission fluid level. The rougher ride is likely from cold tires developing temporary flat spots.
Conversation Summary
The owner of a 2003 Blazer with 144,000 miles reports chirping, intermittent jet-like noise, slight hesitation, and a rougher ride after recent belt, tune-up, and fuel-system work. The symptoms appeared in extreme cold after gas-line antifreeze was added; the truck starts and shows no check engine light. The expert says the cold may be affecting the belt or a weak tensioner, suggests belt dressing and a pulley-bearing check, and advises watching the temperature gauge. Stored codes and the transmission fluid should be checked for the hesitation, while the ride change is attributed to frozen flat spots in the tires.
