2002 Honda Accord Water Pump and Timing Belt
JUDYOBR
Engine Mechanical problem
2002 Honda Accord 6 cyl Front Wheel Drive Automatic 75000K miles
I will be replacing my timing belt at 7 years as recommended but should I be replacing my water pump at the same time? When is it recommended to replace the water pump?
May 14, 2009 at 7:19 AM
F4I_GUY
  • 3,302 POSTS
You should replace the water pump with the timing belt. That is what honda recommends.
May 14, 2009 at 9:36 AM
