Links at the ends come in a kit, has all the parts to replace the rubber and metal pieces. I used to cut them out with a torch, but if there is enogh of the head of the bolt left, unscrew them and install the new ones. the bushing in the middle requires you to remove both links at the ends, and the clamps at the bushings. Some new bushings are split to aid in installing, some arent. Put them on the ends and tap them into position with a hammer, if needed! WD-40 can help with tough ones.
Oct 17, 2009 at 11:00 PM
