2002 Honda Accord sputtering into a stall
12,500 MILES • 4 CYL • 2WD • AUTOMATIC
KDDOYLE33
Upon braking, the car starts to sputter as if it will stall (it hasn't stalled yet). It only happens occasionally and just started at the 125,000 mile mark. I don't know that I could replicate it for a mechanic. Should I replace the fuel filter? Should I just take it to the mechanic?
The check engine light is not on.
Apr 18, 2009 at 1:37 AM
KHLOW2008
  • 41,812 POSTS
Hi kddoyle33,
This is something that requires further diagnostics and professional advice is the best option.
If the idling speed is too low, the symptoms described would occur. Cleaning the throttle body and Idle Air Control valve might resolve the problem.
Apr 30, 2009 at 3:57 PM
