2002 Honda Accord sputtering
2002 HONDA ACCORD
142,000 MILES • 4 CYL • FWD • AUTOMATIC
KENNETH CHALMERS
The problem is that when I sitting idle my shakes slightly. When I press the gas it feels like it does'nt want to pick up speed. It sputters and rattles while picking up speed. Once I get to the desired speed and keep it there it runs fine until I have to stop then it starts all over again.
Oct 18, 2010 at 5:43 AM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 18, 2010 at 12:11 PM
KENNETH CHALMERS
When I asked the question I forgot to mention that the engine light was flashing. I went to have it checked at auto zone but they said that they coud'nt check it until the light stays on. Also prior to the car acting up I went to a cheap gas station before going to work 3 weeks ago and filled it up, as I got on the interstate that's when it started. I have filled it up twice since then and put gas treatment in the tank to try to solve the problem because I believed that was the problem but, since it's still happening I guess not. Thank you for the information rasmataz. Now I have to figure out how much is this going to cost me.
Oct 19, 2010 at 7:41 AM
Go somewhere and get it scanned with or w/o the CEL, you'll probably end up having misfire code/s
Oct 19, 2010 at 7:51 AM
KENNETH CHALMERS
Ok, I will let you know what happens
Thanks
Oct 19, 2010 at 9:49 AM
