2002 Honda Accord Replaced Throttle Position Switch
138,000 MILES • 4 CYL • 2WD • MANUAL
JENKLEINSAC
check engine light doesn't come on. Replaced TPS, car was shaking, push gas, no RPM's. so changed TPS. Still not working. What could it be? Recently changed, timing belt, clutch, and fuel filter (tank). The check engine light never comes on so can't run diagnostics on computer... please advise.
Apr 17, 2010 at 3:31 PM
KHLOW2008
  • 41,812 POSTS
Hi JenKleinSac,
If the CEL does not come on and scanner cannot communicate with the ECM/PCM, you need to trouble shoot the DLC circuit.
I have sent the procedures to your email.
Apr 20, 2010 at 4:25 AM
