Hi mikealford,
FRAME & DRAIN TUBE
Removal & Installation
Remove headliner.
Remove sun roof panel.
Disconnect motor connectors.
Disconnect drain tubes.
To remove front drain tube, remove kick panel. Tie a string to end of front drain tube and pull opposite end of drain tube down and out of front pillar.
To install, reverse removal procedure. Ensure drain tubes are clear by blowing them out
using compressed air. Check frame seal. Clean surface of frame. Ensure drain tubes are installed at least .39" (10 mm) over frame nozzle. Install drain tube clamps with clamp tangs 45 degrees right of vertical. Tighten frame bolts to 86 INCH lbs. (9.8 N.m). Check for water leaks and height adjustment.
© 2008 Mitchell Repair Information Co., LLC.
Sep 18, 2009 at 6:01 AM
