2002 Honda Accord hard starts...sometimes?
120,000 MILES • 6 CYL • FWD • AUTOMATIC
SUPERMOPAR
ok, as an amateur mechanic this is definitely a head scratcher....
vehicle:
2002 honda accord LX 3.0l, 120,000
The engine starts with one turn of the key sometimes. Other times, it takes two turns of the key and the engine will be turning over for about 5-10 seconds before it fires. I'm thinking maybe a crankshaft positioning sensor? i was also thinking maybe a weak battery or starter/solenoid, but it has a new battery, and as far as the starter goes, sometimes it starts on the first crank of the engine. i've looked everywhere but haynes/ chiltons manuals and that's my next stop. any help would be GREATLY appreciated.
Aug 8, 2010 at 12:56 PM
KHLOW2008
  • 41,812 POSTS
Hi supermopar,
If the difficult starting occurs only after the vehicle is parked for prolonged periods, then I would suggest get the fuel pressure tested for leakage.
Aug 9, 2010 at 7:02 AM
SUPERMOPAR
thanks for the advice!! ill get a gauge on a bleeder valve and see where i'm at.
Aug 10, 2010 at 2:21 AM
KHLOW2008
  • 41,812 POSTS
I have encountered a few casews of the fuel filter leaking and as it is intank, it would not be noticed.
The pressure leak is not instant so you might need to hold the pressure for a while to see if it drops and how fast.
Aug 10, 2010 at 2:38 AM
