2002 Honda Accord Gear indicator light
2002 HONDA ACCORD
SWEETMICHELLE
Interior problem
2002 Honda Accord 4 cyl Two Wheel Drive Automatic
Can the light source be replace for the gear indicator console and the key hole ? If so, can you tell me where to find directions to get to the bulb or fuse.
Mar 27, 2009 at 4:22 AM
KHLOW2008
  • 41,814 POSTS
Hi SweetMichelle,
To replace the key hole bulb, you have to remove the steering column cover to gain access. There are a few screws that is attached from below.
To replace gear shift illumination light bulb, you need to remove the center console.
Mar 29, 2009 at 6:26 AM
