2002 Honda Accord fueling the car
ANNAG161
Engine Mechanical problem
2002 Honda Accord 4 cyl 110000 miles
I am having a problem when i go to put gas in my car. after inserting the nozzle in the tank and depressing the handle to start gas flow, it cuts off every 2 seconds. You can imagine how long it takes to put $20 in when it clicks off all the time. I have tried putting less off the nozzle in the tank to release the air vaccum but not working...at first i thought it was the gas pump, but it happens at other stations as well.
if it is a vaccum issue, how do i check for it?
Aug 27, 2008 at 12:16 AM
KHLOW2008
  • 41,812 POSTS
Hi annag161,
You need to check the fuel inlet pipe, its ball valve and its attached bypass hose/tube.
Aug 27, 2008 at 3:53 AM
