2002 Honda Accord Engine Replacement
60,000 MILES • 4 CYL • AWD • AUTOMATIC
VANUNEZ
Olil leaking from under engine took car into Honda Dealer. Paid $2600 because Dealer found oil leaking from cylinder head gasket due to engine over heated due to faulty radiator fan switch. No warning light ever came on when I was driving the car. Dealer installed a special order head gasket and seals, radiator fan switch, retorqued all hardware to factory specs bleed cooling system. Took the car home, twelve days later, I noticed oil leaking again. I took it the dealer, now I am being told the engine is warped and a whole new engine is needed!!!!! Is this common?????? I can believe the Dealer is making me put in a new engine, when they seem to have diagnosed the problem wrong the first time.......
Aug 9, 2008 at 4:24 PM
  • 31,937 POSTS
Hi there,
I would be getting a second opinion, to warp an engine block you would just about have to cook it to death in the first place, it may be a problem with the work they did in the first place.
Mark (mhpautos)
Aug 9, 2008 at 7:41 PM
