2002 Honda Accord Engine burns oil
106,254 MILES • 4 CYL • FWD • AUTOMATIC
PLUGIN
Hi, my car for some reason is burning oil. My car doesn't leak oil because I always park my car in the garage and there never has been a leak on the ground from it. But what I do noticed and realize that there is a problem and it's that I am always having to add 1 litre of oil about every 3 weeks just to keep the oil at level. When driving, my car doesn't show or make any signs of bad smoke from the back. So if it's not leaking oil, and not burning oil from the exhaust pipe? What would be the case why I am always having to add more oil so often because of the oil level being low? Thanks.
Jan 25, 2010 at 12:31 PM
KHLOW2008
  • 41,812 POSTS
Hi plugin,
The most common cause of Honda engine oil consumption are bad valve seals.
The catalytic converter can reduce the amount of smoke emission due to burning oils so you might not notice excessive smoke even when oil is being burnt.
Jan 29, 2010 at 3:07 AM
