2002 Honda Accord
86,000 MILES • 4 CYL • FWD • AUTOMATIC
AMARANNA
  • 15 POSTS
at low speed car jerks at start and stop. wat will be the issue.
May 21, 2010 at 11:27 AM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 21, 2010 at 11:42 AM
AMARANNA
  • 15 POSTS
below is the reply i got from other forum -
Symptoms indicate a possible fault with the transmission. The jerking could be harsh shifting and when slowing down, the clutches engages with a jerk. I believe it is more likely to be 2nd speed rather than 1st.
Usually when transmission problems occurs, the PCM would store a trouble code. Get a free scan done at Autozone to see if any trouble codes are stored in the PCM.
May 21, 2010 at 12:05 PM
  • 75,988 POSTS
The PCM uses the TPS and VSS to control the upshifts/downshifts/overdive/lock-up-could be a sticking shift solenoid
May 21, 2010 at 1:38 PM
AMARANNA
  • 15 POSTS
Does PCM store transmission issues also ?
May 21, 2010 at 4:45 PM
  • 75,988 POSTS
Check if it has a transmission control module this where you pull code/s if none could be the PCM itself
May 22, 2010 at 4:32 AM
AMARANNA
  • 15 POSTS
i notice a Jerk after the car had come to a complete stop.
Some people say it might be Transmission, some say Crankshaft Synchronizer issue. Pls help to clarify.
if i want to replace the transmission, where should i do it. i live in Minneapolis. Some say do it in AAMCO
pls advice and give me more details on the rebuilt Transmission
Aug 19, 2010 at 1:53 PM
