2002 Accord vibration when 50+ mph and br
107,000 MILES • 4 CYL • FWD • AUTOMATIC
AMARANNA
  • 15 POSTS
i bought a 2002 Accrod from the dealer. front tires are new. rear tires have only 4 points and have edge wear. when going above 50+ and braking it vibrates and drive is not smooth.
is the vibration due to bad tires are need to check the alignment. also i see the streeling wheel little tilt.
i am ready to change the tires, but just wanted to make sure the reason.
Also is there any way to identify whether the timing belt is changed or not. Dealer told it was changed by the previous owner
Pls advice.
Mar 21, 2010 at 8:45 AM
HONDA TECH 1818
  • 536 POSTS
The pedal pulsation is due to warped font rotors, replace the front brake pads and machine the front rotors.
The only way to check the timing belt condition is to remove the timing belt top cover.
Mar 22, 2010 at 6:42 AM
