2001 Honda Accord What coulld be wrong?
2001 HONDA ACCORD
205,000 MILES • 4 CYL • 2WD • AUTOMATIC
WHITNEYP
my car has started to shut off alot lately. When i crank it up if it will start and put it in reverse it does a shake and cut off. SOmetimes it starts up fine though. It was only cutting off every two months or so but the problem has gotten worse and now its shutting off twice a day every other day if not more and takes an hour or more to crank up after having this problem. A lot of people are talking about the fuel pump but when the car runs it dont run bad at all. It dont over heat what so ever. I dont know what could be the problem. Any suggestions? thank you for your time.
WHitney
Sep 28, 2009 at 2:57 PM
KHLOW2008
  • 41,814 POSTS
Hi whitneyp,
If the dashlighs do not indicate when the engine stalls, the problem could be due to a faulty ignition switch. There was a safety recall on the item and you can check with your local honda dealer.
If it is fuel that is missing, check the PGM-FI main relay, it could be intermittently failing.
Oct 4, 2009 at 8:26 AM
