2001 Honda Accord throttle
128,000 MILES • 4 CYL • 2WD • AUTOMATIC
RENEMIRANDA
When I started the engine it was ok,after 30 seconds. The arrow went up and down until it was warmed up. After that it was okay. I changed the spark plugs, air filter, and the PCV valve.
Dec 4, 2009 at 11:50 AM
KHLOW2008
  • 41,812 POSTS
Hi renemiranda,
Do you mean the tachiomater is surging up and down?
If yes, you have a cold start idle control problem and the most likely cause is a sticking Idle Air control valve, lack of coolant or coolant hoses to IAC is clogged.
Get the IAC cleaned and retest.
Dec 7, 2009 at 12:25 AM
