Shifter Bulb Replacement
2001 HONDA ACCORD
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
JLAUD
How do I disassemble, replace the bulb and then reassemble the center console of my 2001 Honda Accord?
Nov 10, 2008 at 3:53 AM
This just requires removing the center console and you should be able to access the bulb from there. However, if needed you will need to take the shifter loose.
I am attaching the info below on how to do this.
Please run through this material and let us know what other questions you have.
Thanks
Oct 14, 2021 at 12:42 PM
