2001 Honda Accord Rough Idle
TEDAQUATIC
  • 2001 HONDA ACCORD
  • 4 CYL
  • 83,000 MILES
Hello again. My car idles rough in park and when in-gear at a idle position. When driving, it purs like a kitten. I have done a major tune up, replaced (1) bad motor mount - but still seems to idle rough - When it warms up. It seems to idle a little smoother but still not where it needs to be. Any suggestions? I am thinking of trying some fuel injection cleaner to see if that may help with the problem ? Your thoughts?
Friday, May 28th, 2010 AT 2:05 AM
KHLOW2008
  • 41,814 POSTS
Hi tedaquatic,
Do you mean the idling speed is too low, is it surging or misfiring?
Friday, May 28th, 2010 AT 12:28 PM
TEDAQUATIC
  • 6 POSTS
No - The Idle speed is where it's supposed to be according to factory settings. With and without the A/C on. It is not idiling too low, surging or mis-firing. What else could be causing this sitiuation?
I have also had a coputer diagnostion run on the engine and all checks out well?
Friday, May 28th, 2010 AT 5:20 PM
KHLOW2008
  • 41,814 POSTS
What do you mean by rough?
You are feeling a lot of vibrations?
Engine seems to miss intermittently?
Saturday, May 29th, 2010 AT 8:56 AM
TEDAQUATIC
  • 6 POSTS
When I mean rough. It is mainly felt in the steering column when in park & drive mode. The egine does not miss. Other than that it runs great.
Saturday, May 29th, 2010 AT 11:26 PM
KHLOW2008
  • 41,814 POSTS
So you are referring to vibrations when the gears are engaged at a stopped position.
This is usually due to bad engnine mounts. There are 3 major and 1 minor mounts. One have been replaced, but did you check the conditions of the other mounts?
Sunday, May 30th, 2010 AT 8:19 AM
