Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Accord
Drivetrain
Bearing Hub
2001 Honda Accord rear hub assembly
2001 HONDA ACCORD
40,000 MILES • 6 CYL • FWD • AUTOMATIC
MFERRARO02
MEMBER
1 POST
Does the rear hub asembly need to be pressed off and on the spindle to replace it or is it a slip fit on and off?
May 17, 2009 at 1:24 PM
KHLOW2008
Experienced Mechanic
Hi mferraro02,
The rear hub comes as an assy with the bearings and is installed as a unit. No disassembly and assembly of unit is required.
After removing the brake caliper and mount and the rotor, removing the central bolt would allow you to remove the hub assy.
May 24, 2009 at 5:45 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
