2001 Honda Accord High/low beam lever malfunction
124,000 MILES • 4 CYL • FWD • AUTOMATIC
LEGALBASS1
High/low headlight beam lever on colum very loose. Left and right turn signal works , but lever will not click and stay from low to high beam. Possible cause
May 26, 2008 at 2:35 PM
KHLOW2008
  • 41,812 POSTS
The spring loaded lever for switching between low and high beam inside the switch unit is broken. You need to get a new the unit.
May 27, 2008 at 2:33 AM
