2001 Honda Accord firing problem
LEROY3031
  • 2001 HONDA ACCORD
  • 4 CYL
  • FWD
  • 211,000 MILES
Well I was driving home one day and it just seemed like my car ran out of gas. And it kept trying to turn over but it was like I had noo gas in it. And I know that I had over half and tank. Soo I thought it was the fuel pump so I got a new fuel pump and put it in and nothin it still was doing the same thing it was doing before I put it in. Then I checked to see if my spark-plugs were firing and I wasnt getting anything soo I talked around and one guy told me coil package and another told me engine module or maybe control module and I have no idea which one it could be. Or even if it is one of them. Soo could you kinda point me in the right direction on what to do next?
Tuesday, September 14th, 2010 AT 10:57 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Also check the fuel pressure if it's within specs.
Wednesday, September 15th, 2010 AT 12:23 AM
LEROY3031
Well I checked to see if it spark and there was NOT a spark at all. And I just replaced the spark plugs, wires, distributor, and the rotter button like maybe 4 months ago. Then I checked all the fuses to make sure it wasnt something small. I cant figure out whats wrong with it
Thursday, September 16th, 2010 AT 3:44 PM
Check and test the crankshaft position sensor-
Thursday, September 16th, 2010 AT 5:47 PM
