2001 Honda Accord ECU LIGHT
2001 HONDA ACCORD
68,374 MILES • 4 CYL • FWD • AUTOMATIC
PEEJAY8
I HAVE THE ECU LIGHT ON TELLING ME P1166 CODE AND P1167, I HAVE REPLACED THE O2 SENSOR AND CLEARED THE CODES. THEN IT COMES UP WITH THE SAME CODES AFTER THE ENGINE RUNNING FOR AROUND 30 SECONDS ANY IDEAS
Sep 16, 2009 at 5:45 AM
F4I_GUY
  • 3,302 POSTS
3 fuses to check first. #14 under hood (30A), and #2 (20A) and #4 (10A) under dash. My bet is #2 is blown, probably a short in the sensor or wiring, you'll know if it blows again.
I believe these are the right numbered fuses, if not, just check all your fuses with a testlight or fuse tester.
Sep 16, 2009 at 6:58 PM
