2001 Honda Accord clutch problem
77,000 MILES • 4 CYL • FWD • MANUAL
NEWROMANCER
I have had a changed complete clutch but theroblem didnt dissapear.when the engine is cold clutch is good n pedal works on the bottom position..when am driving longer n engine gets hot the clutch starts to work in upper position.its same every day.sometimes when its hot the clutch is not slipping but when u starts from hill upress gas n releasing clutch it starts shake the whole car...i have higher rpm but it still shakes.something have to be wrong with clutch...we changed all liquid for new one,change complete clutch,nothing works...
Aug 11, 2009 at 7:52 AM
KHLOW2008
  • 41,812 POSTS
Hi newromancer,
Symptoms indicates pressure is building up after heating up and the probable cause is either a faulty master cylinder or there is insufficient free travel between the clutch pedal and master cylinder push rod.
Aug 16, 2009 at 8:31 AM
