2001 Honda Accord Car shakes when accelerating 40mph-60mph
120,000 MILES • 6 CYL • FWD • AUTOMATIC
MADSEADOO
Car is a 2001 V6 accord sedan. Whenever the car accelerates from 40mph-60pmh the sterring wheel and car vibrates and stops when 60mph is reached. Also, the car vibrates when brakes are applied at higher speed (>60mph). The car has new struts and springs x 4(only a year old). Rims are after market (17inch) with new tires(6 months). Wheel balance and alignment has been done. Transmission was just replaced by dealer in 2004. I have replaced the front brake rotors as well as the back. New brake pad have just been installed. The honda dealer have told me to change everything from Ball bearings, CV joint, front axles, etc. That would come up to be more than $1000. Any suggestion would be very helpful. Thanks
Jan 11, 2008 at 5:41 PM
  • 31,937 POSTS
Hi there ,
Vibration under braking is 99% time brake rotor run out, if they are near new have then check for run out, before machining, As for the steering vibration, have the wheel balance re checked a wheel weight may have come off, Have a look and make sure there is not weights opposing each other, incopentent wheel balance operators do this.
Mark (mhpautos)
Jan 12, 2008 at 12:06 AM
LEGITIMATE007
  • 5,121 POSTS
just for the heck of it ,, check all of your spark plug wires and make sure none of them are damaged and arcing against the block.
Jan 12, 2008 at 3:48 AM
