2001 Honda Accord Alternator
144,000 MILES • 6 CYL • FWD • AUTOMATIC
HONDA2001
How to remove alternator step by step
Dec 13, 2009 at 1:37 AM
KHLOW2008
  • 41,812 POSTS
Hi honda2001, Here are the procsdures 1 . Ensure you have the anti-theft code for the radio. Write down the frequencies for the radio's preset buttons. 2 . Disconnect the battery negative cable. Disconnect the positive cable. 3 . Move the auto-tensioner "A" to relieve tension from the alternator belt "B", and remove the alternator belt. See Fig. 17 . 4 . Disconnect the condenser fan motor connector "A" from the condenser fan shroud. See Fig. 18 . 5 . Remove the condenser fan/shroud assembly "B". 6 . Disconnect the 4-pin connector "A" and Black wire "B" from the alternator. See Fig. 19 . 7 . Remove the mount bolt "A" and alternator bracket mounting bolt "B". Remove the harness clamp "C" from the alternator bracket. See Fig. 20 .
https://images.2carpros.com/forum/automotive_pictures/192750_AlternatorRemoval01Accord6cylFig17_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_AlternatorRemoval01Accord6cylFig18_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_AlternatorRemoval01Accord6cylFig19_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_AlternatorRemoval01Accord6cylFig20_1.jpg
Aug 24, 2020 at 7:32 AM
