i hear a thud kind of noise when i put my car from park to reverse or from reverse to drive. i was told it could be transmition or cv joints
Apr 25, 2008 at 9:02 AM
YAM
MEMBER
I would have to say transmission problem if you are hearing it from your transmission, b/c cv joints would make a bit of a different sound, honda may replace the transmission,but i would check with them, there was a recall on the 01 accords, and i recently had my changed out due to it still being within the warranty period, so check with them, b/c if gears start slipping you will be in a worse postion!
