2001 Honda Accord
128,000 MILES • 6 CYL • FWD • AUTOMATIC
AMYJORDAN
My car is pulling to the right and is making a grinding/scraping noise when I turn the wheel going forward and backwards. It sound like the noise is coming from the front right side. What could be the problem?
Jan 12, 2009 at 10:20 AM
DAVE H
  • 13,383 POSTS
check WHEEL BEARING
Inspection
Wheel bearings require no adjustment. Bearings should be checked for excessive movement. Support vehicle, and remove wheel.
Install dial indicator with stem positioned on front hub surface. Move hub assembly in and out. Note reading. Movement should be 0-.002" (0-.05 mm). If movement is not as specified, replace bearing.
also check front brake caliper's are not sticking
Jan 12, 2009 at 1:45 PM
