How do you replace turn signal and blinker switch on 2000 Honda Accord LX?
Nov 10, 2008 at 8:55 AM
KHLOW2008
✓Experienced Mechanic
Hi BRE2000.
You need to
1. Remove the steering wheel. If equipped with airbag, make sure the cable reel is correctly adjusted when installiing, failing which you would damageit.
2. Remove the upper and lower steering column cover.
3. Remove the screws holding the switch and unplug wire connectors.
